1979 Starcraft Holiday16 closed bow
ezmobee
Re: 1979 Starcraft Holiday16 closed bow
Good work so far. You have to have had the least successful leak test on iboats :p
Daltonxj
Thats ok now i get to learn how to repair it LOL i'm enjoying myself...
once all this leak stuff is out of the way it won't be long till splashdown...
North Beach
Sorry Dalton, I mis-spoke. Should have said panhead bolt. You know, flat where it meets the shank and rounded on the top like the rivits in your boat. Mine were phillips head.
And don't let E get to you:D I had over 30 leaks in my Mariner:p
Now let's re-visit that it won't be long to splashdown remark..........
CBGale2
OK I these can't seem to figure out what was mounted there outside or inside??
same on otherside.
and now the big one!!!
Bow mount thrusters where mounted there. :D
Daltonxj
Bow mount thrusters ??????
any pics?
or j/king????
confused!!!:confused:
jasoutside
Same set up as this...
Starcraft sold the technology to VW which was a real bummer:mad:
Daltonxj
LOL thats funny......
No really I need to know what was there inside or outside...
CheapboatKev
Thats only because RickAirMed didnt do one..:eek:
He had those stringers screwed THROUGH the hull..Which I think whomever owned this boat before did when working on this deck..
CheapboatKev
Nothing outside...really think the Prev Owner F'D it up..
Patch her and dont loose anysleep, cept for dreaming of sunny days and the water beneath your feet
Daltonxj
I know was just wondering about them holes cause they are the exact same distance apart and the same distance from the top and from the rear of the boat but looks like JB weld will be repairing them...
CBGale2
There is no telling what happened there. The PO probably had something mounted in there and took it out and didnt plug the holes up???? I looked at a little row boat once that a guy had mounted all sorts of stuff on the back with 2 inch black drywall scews through the aluminum, leaving the business ends of the screws pointing into the boat. People do crazy things.
Daltonxj
so do I just use jb weld or do put a blind rivit and then jb weld?
and this part here?
where can I get the rivets to reinstall this at? or can i use the panhead bolts with 5200?
CBGale2
For those mystery holes I would just coat up a rivet good with some 5200 and call it good.
I'll leave that knee brace to the experts, havent messed with one of them.
bananaboater
Ensign
and this part here?
The bottom of that bracket was attached with bucked rivets and the upper part was set with "truss" style aluminum (original) or stainless machine screws through the transom. When you reattach it be sure it is strong.
Those holes look like they are right at the curve of the chine. However you fix them keep it smooth.
You are asking the right questions and are getting good advice. Keep up the good work.
Daltonxj
Thank You for the good advice now just to find the rivets.
what plywood do I use to make the transom can I just get PT plywood?
jasoutside
Nah, you'd be looking for marine grade or exterior grade. PT is asking for trouble!
Daltonxj
can I get exterior plywood from homedepot? I went and looked there today only found 23/32 and some birch plywood that was it....
what else would I need to complete this task???
Daltonxj
When I build the transom can I use home depot 3/4 plywood glue it together and use fiberglass to make it sealed??
I know glass resists water. Will that work?
or do I need to do anything else?
oh and where can I find this stuff called Gluvit. so I can get it ordered.
