I have a 4.3 L v6 Chevy block OMC I/O motor with a manual fuel pump which just went up its the original pump.
Should I switch it over to an electrical and if so where would I find a conversion kit for it? Or would it be better to just stay with manual?
Also the rod that pushes down on the mechnical pump how can you tell if that is working correctly and if I switch to electrical how would I cover that up?
Thanks for any info you can give
