Nmea connections eagle intellimap / m tech mt500 dsc radio
scotty628
Hey all, i am having a mare when trying to connect these 2 hardwear items together. after reading the instructions im baffled. Has anyone connected these two together before?????????? Any help would be greatly appreciated.
Cheers
RickJ6956
Re: Nmea connections eagle intellimap / m tech mt500 dsc radio
NMEA data is almost always RS232 (standard com port) which uses one wire to transmit, one to receive, and one common ground. The "transmit" of one device must connect to the "receive" of the other. The cable shouldn't be more than 50 feet long, and it should be "2 conductor shielded."
GPS transmit = Yellow to radio's brown
GPS receive = Orange to radio's red
Common/ground/shield connected together.
The baud rates of both device ports must then be matched. The GPS manual says to call the factory to obtain the settings and learn how to interface devices.
scotty628
Rick,
very many thanks for the reply and apologies for my time as i have just started looking at solutions again and saw the reply. ill give it a bash this weekend. Thanks again for ` clear guidance`. scotty
dchris
There are a number of free NEMA test programs that you can use to check your devices by connecting them to a laptop. NEMA is usually 4800 buad, 8 bits , 1 stop. But it can vary.
scotty628
DChris,
thanks for the info. I connected the two units up and they dont seem to communicate yet. Am i right in assuming i need to enter my mmsi number into the radio or does this not matter at this stage? baud rate on intellimap is 4800 and i have checked the nmea output box only so i guess it transmits to the radio. Does this sound correct??????
seabob4
Since I did some looking around, these are both 0183 units aren't they?
turbinedoctor
Did you check the communication settings on the GPS to make sure they match what the radio is looking for?
scotty628
hi guys and thanks for your input. i have read the instruction manual for the MT500 - RE NMEA - All it says is the $gprmc/gga sentance is decoded NMEA checksum can be turned off. The plotter states it is 0183 connection. I have connected as instructed by Rick on this forum. ie:
GPS Yellow to DSC brown (Tx)
GPS Orange to DSC Red (Rx)
2 ground / plain bare strand together
the plotter menu offers:
nmea input
nmea gps input
nmea output
which one should i go for????
does this help?
scotty628
Whoops just to confirm both the MT500 and the 502 are NMEA 0183 compatable.
:rolleyes:
RickJ6956
The manual tells you to "call the factory" to learn how to interface devices, so I'm guessing it's not as simple as it seems. No doubt Eagle has a tech support number in the UK.
scotty628
Rick,
Yes indeed you did mention that in your first reply. I hace emailed Eagle UK and await a response. Cheers
dingbat
nmea input
nmea gps input
nmea output
does this help?
After looking at both manuals, you need to connect the yellow wire (TX) from the GPS to the brown wire (RX) on the radio. The units don't support Bi-directional communcations so the second connection is not required. Tie the grounds/shields together and ground them to a good solid ground conection Some units require you connect the TX(-) and RX (-) to ground as well.
scotty628
dINGBAT CHEERS, SO I TAKE IT HAVE TO REMOVE THE ORANGE TO RED ONE?
dingbat
Yellow goes to brown. Tie the shields /grounds to the system ground.
scotty628
Cheers, ill give it a try and report back. will have to be at the weekend though now.
