Adding to my list of problems
83vert
Re: Adding to my list of problems
There must be a hole in one of the boots because there would have to have been a ton of water in the boat to get in there but after all this bull**** nothing would surprise me. I was going real good there for a while and then the pins:mad::mad::mad:
HVAC Cruiser
Hey Vert,
Sorry to hear your still having trouble with it. You want a hand with it tomorrow? give a call and let me know, I can come over after I take Liam to school at 9am
Bill
83vert
I am making progress a little at a time. Do they sell replacement washers for in between the bell and the bell ring? Will it be a problem if I do not screw the trim sensor and the limit switch back over the hinge pins?
This is what it did look like when I brought it home. Now I know why every bolt and screw is siezed.
HVAC Cruiser
Hey Vert,
You can have the shim washers off my other Gimbal, we just have to take it apart no biggie its already off the boat
Bill
NHGuy
Hey, I just put new ones in yesterday, $1.37 each at dealer. They are called synthane bushings by Mercruiser. BTW you put red Locktite on the pivot bolts and torque them to 90 foot pounds. Although where you go ( salty & corrosive) you might ask the locals whether they do the locktite.
83vert
Yea Bill I will definetly take em, although battling with hinge pins sure does make me nervous :eek:. I will drop the torch off one night this week after work(had some oil burner problems over the weekend). NHGuy I think your right about finding out wether to use loctite or not with salt water. Maybe just not red loctite? I ordered a wheel bearing puller and I just need to get a new shift cable and I have everything to complete the job.
boat127
those washers are glued on they have a wax backing you take off but if you can get the others off put the hinge pins in then put the washers on because if your jsut a hair off center it will be a pita to put the hinge pins in when you go to install the belhousing to the gimbal ring
