Hello all,
I have a 15 ft duratech aluminum with a 1960 Gale 35 HP. The motor will run great, shifts fine, no hiccups or anything. Well at any rate, here is the deal. I took it out today to get it all tuned in and what have you, but at WOT i was only doing 6.8 MPH.
Im 99% sure its not trim. It seems almost like it is running way too rich of a mixture, but right on the cowel it says 24 or 25 to 1. It is getting plenty of fuel. Also when in neutral it seems to rev up ok.
I pulled the plugs and put it in gear to turn the prop to feel for any lower unit binding and there was none.
I have no idea where to go from here. maybe a spun hub? but how would i tell it looks like the entire prop is metal no rubber or anything.
Thanks in advance
Thanks in advance
