1984 8 hp evinrude still only runs choked
90F1504x4
new fuel pump new lines cleaned carb new plugs checked fire from both coils it will idle with out being choked but cant rev with unchoked seems to run fairly decent with the choke on
walleyehed
Re: 1984 8 hp evinrude still only runs choked
Main jets or something in the high-speed circut of the carb is still plugged...
What did you set the float level at?
90F1504x4
not sure just put it back the way it was
wilde1j
Cleaned carb how? Complete disassembly and soaking, then replacing or cleaning every orifice or jet?
90F1504x4
yes sir seems to be running great now after cleaning carb again will know tonight after puttin in lake to see if she is right now for sure
90F1504x4
ran great for about an hour and then it started the same thing im thinking that particles from the foam insulation on the cowl is getting in the carb so i took all of it off and cleaned it good also the thing the throttle rides against broke half way so you cant run past half throttle im looking for one now
90F1504x4
does anyone know what the name of that part is and where i can get one it is the black plastic ramp that the roller on the throttle rides against
walleyehed
An in-line filter designed for outboards (pre-mix) would be a good addition too.
Brianjason6
He's speaking of the piece that bolts under the flywheel. When you turn the throttle it pushes the carb open. I don't know the name but you can locate it in the parts manual. Leave the model number and someone can find the part I'm sure.
90F1504x4
your correct what parts manual are you talking about i still cant find anything on it
Rick.
90F1504x4
oh thanks i didnt see that thats a very good site
