cedarjunki
- Joined
- Aug 23, 2007
- 472
Re: Starcraft SuperSport Restoration (18 footer)
that looks alot like cedar on the shelf
gee, too have that just sitting around you must be rich.
just kidding.
keep up the work, looks good
Got the leak test done this afternoon, and only had a few rivets that leaked very slowly. I'm not going to tighten them i'm just going to use the gluvit. Got the new transom board cut, glued and screwed. It was a tight fit. I'll do a little sanding and shaping as i had to cut it from a cardboard pattern i cut from the old rotted transom. I'll slip it in and predrill my drain holes, bolt holes and the mounting holes. I opted to use liguid nail (exterior) and smooth it out with a trowel for maxium surface adhesion.
I will order my epoxy in the morning and pickup some more MEK. The 90 plus weather didn't let the MEK last very long. I only have a little glue left and i'll get her cleaned up for the Gluvit.
I have to make up my mind on floatation as well. I need to find some blue or pink board or a source on about 75 noodles. My lowes did not stock it for some reason.
