INDYCAVER1
Thread starter- Joined
- May 15, 2010
- 51
Hey, I just took my boat out for the first time today. I did alot of work to the hull, but not much to the motor since i have had it. The motor runs fine when hooked to the hose. It will rev up in gear and run fine all through the rpm range in gear, but in the water under load, it stalls after I get it past about 2200 rpms. It runs great from idle to 2200 though. when i got it home i noticed one of the nuts holding one side of the carb on was really loose. Does anyone think that could have been my problem? I thought it could have been sucking in too much air since the carb was loose and starving for fuel when i really got into the throttle.
