I have a 1976 evinrude 200hp. The trim will go up but not down unless i turned the bypass screw out. I talked to one guy and he thought it sounded like the motor wasnt working right. I just got done putting a new motor in and its doing the same thing. It sounds like its working fine but the motor wont go down. It sounds like there is air in the lines. I crack the lines loose at the piston and and run the motor fluid comes out. Is it possible that the piston is shot?
Thanks
Bill
Thanks
Bill
