FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
how do you measure to see if motor is short or long shaft? i have a 1966 johnson 9 1/2 and beleive it is a short shaft but i want to buy a newer johnson or evenrude but want a long shaft, thanks ken
The long shaft 9.5 has a 5" extension bolted between the gearcase and the midsection. The standard is 15", model #MQ-12. The long is 20" model #MQL-12.
You can make the MQ-12 a 20" with an extension kit.
Long shafts have a 5" extension in the middle (easy to spot). So it is either a 15" short shaft or a 20" extended long shaft. Measure from where it sits on the transom down.
Long shafts have a 5" extension in the middle (easy to spot). So it is either a 15" short shaft or a 20" extended long shaft. Measure from where it sits on the transom down.[/QUOTE
Down to where though. I've wondered about this measure myself. Is the five and ten inch extension an OMC solution or do other manufactures do the same thing to achieve a long shaft? Rick.
