temp sensor and coolent leak.
blueagletalon
i have been chasing my temp sensor problem since i got the boat. i have rang out the one wire going to it. i have replaced the sensor and the guage. i followed my manual on troubleshooting . im lost, i can not find anything wrong. so im writing you guys for help.
my coolent leak seems to be comming from the water pump area. i did notice that all the bolts are kinda loose. so im going to re torque them tomorrow night. has anyone had problems with bolts working them self loose? if so what kind of locktight cand i use.
my boat is a 1987 thomson 185 cutlass. with the 3.7 mercruiser 470 motor.
Don S
Re: temp sensor and coolent leak.
Exactly what is your problem.
Ayuh,... Is the gauge Powered with 12V,..??
Is the Sensor properly Grounded,..??
The water leak is a sign of potential catastrophic failure....
Rocky_Road
Did anyone use teflon tape on the sending unit threads?
The sensor uses it's pipe threads (no tape needed) to make the ground it requires. Weak ground= no work!
Happy boating!
stonyloam
Take a close look at the lower starboard side of the engine water pump. There is a small weep hole there. Is the coolant coming from there? If so, you need new camshaft water pump seals. Common problem with the 470's. If it is, read this it will help you understand what is going on: http://www.sterndrives.com/470information/470coolantleakrepair.html
blueagletalon
i was reading the link and it says that i have to have some special tools. now cant i use a 3 point jaw puller? plus do i really have to pull the engine?
stonyloam
Not sure on the puller. You do not have to pull the engine if you have room to get the harmonic balancer off.
blueagletalon
ok i do believe i have the room. now i have to order seals.
