I did some searching and reading on here and it sounds like my safety switch. I have a 16' Logic center console with a Evinrude 50 4 stroke. I never use my lanyard and forgot all about it this year. Today I hit a decent size wave and ten seconds afterwards the motor cut off and would not start. I crawled under the console and found this little block box about 1" x 1" with a 1" long strip of metal that, if pushed makes contact with a little switch. I played with it and noticed that it would kill my connection when trying to start the boat. It has two yellow wires running to it. I assume that this is the kill switch. I found where it fell from and placed it back and made it back home. Question is can I cut the two yellow wires, connect them together to bypass the little black box to avoid this again?
Thank You
Travis
Thank You
Travis
