Phazer230
Thread starter- Joined
- May 28, 2009
- 108
Hi this is my first boat restoration job and I have done a ton of research but still have alot of questions, so please bare with me. I have the rotted floor removed, the engine out, the foam out and I am in the middle of removing the stringers and engine mounts which are also rotted, so this will be a 100% under the floor rebuild. I am only removing a couple stringer sections at a time because of the support issues " my boat is on roller trailer" arrrrr. My main support stringers seem to be in 3 different sections anyway and the rear engine compartment stringers really wernt connected to the main stringers anyway, just a piece of 2x2 sandwiched between them, the 2x2 wasn't even glass or epoxied in. Now for some of my questions, I would like to know how and what to use to properly install and bed my stringers and the proper materials to use to do so? First off a stringer is not acually suppose to come in contact with the hull at all is it? With that
being said I thought about using that window foam tape that you can buy at walmart, it may be to thick though I don't know I think it is like 3/8" thick. What do you guys think? I
was just going to stick it on the bottom of the stringer longways and leave it in place. I have heard of alot of people using PL Adhesive, can you bed the stringer in this stuff or is it just for filleting the stringer in place???? Can you use the PL to so called glue the stringer in place? Untill I glass it in? Another concern of mine is I would like to glass my sencondary stringer before I install them, the manufacurer only glassed one side of the stringer and I think I know why, where this outer stringer goes is a 1" trench in the hull of my boat which would make it hard to glass in on both sides with no voids! That is one thing I would like to do is fill this valley with the PL right before I set the stringer in, to fill the gaps. Right under this valley is where the rigdges are on the bottom of my boat, I think this is one reason the boat is sitting on a roller trailer because the points or ridges are right in the middle of the rollers, a bunker
trailer probably would not work too well. This valley is why I will be using 1/2 ply for this stringer cause 3/4 will not fit in the groove, oh well. This outer stringer is nothing more than 1/2 ply 6" wide with a very slight curve to the front and 8' long so it should be real easy to make, the front of the stringer was no where close to touching the hull anyway I could see that easily when I was removing it. It had foam under the stringer, so I guess it doesn't need to be cut out perfectly? I would also like to know what kind of fiberglass mat I need for everything? Engine compartment, stringers, floor ect. Would 1.5 be ok for everything? I was thinking of getting the epoxy from US Composites. I would like to restore and improve the bottom of my boat cause it looks like the manufacturer did things I don't approve of like 1. They didn't glass the top of the stringers!!!! 2. they used staples to install the floor! This isn't right is it?shouldn't the
floor be epoxied to the stringers????? 3. They didn't put any drainage holes in the stringers whatsoever and the water just sits between the stringers. These are things they did that I would like to correct, I do not want to fill the boat back up with foam either! I am officially a foam hater. I will try to get plenty of pictures posted when I get a chance, to let you guys have a better understanding of what I am dealing with. Thanks
