Please explain differences in correct/incorrect Chrysler 35/55 series, "Frank mention
Please explain differences in correct/incorrect Chrysler 35/55 series, "Frank mentioned?.
NO---NO---NO---
"Chrysler made two series of 55 engines and two series of 35 engines. The correct series is the 35, 45, 55 series. Incorrect engines would be a 35 from the 20, 25, 35 series or the 55 from the dual carb 55, 60, 65 series.
There is no matching. ANY Chrysler 55 with a single carb can use ANY shaft from a 35 (not the 35 with a 25 block and leg), 45, 55 short shaft engine. Diameter was the same and splines were the same."
Would the model and serial # dictate if you have the correct or incorrect 35 HP Chrysler? I have a Mod. 3555, Ser. 2365, would that be the correct or incorrect and why? I'm missing what make them correct or incorrect. Is it the sequencing of HP that make them correct or incorrect and how is that known (manuals)? Thanks for the explanation.
JOW
