FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I was paging through my father's Mercruiser service manual last weekend. He has the 2.5 litre 120hp Merccruiser and the max rpm for that motor is 4600 rpm. I believe it is the same for your 140 hp. Just thought I'd throw that into the thread here.
Are you the original owner?
could the drive have the wrong gear ratio?
Was the drive ever changed?
compression readings with throttle wide open
firing order 1,3,4,2
Have you verified your carb is going to full throttle.
Good fuel,
good fuel pump, timing correct, exhaust plugged with the flapper valve,
are you maitaining good fuel pressure to the carb.
Old fuel lines will swell shut especially if you have old fuel lines and eth. fuel.
What pitch prop do you have?
What size boat.
