older johnson
fis
i have a 5.5 johnson.the year is 1954-67.the plate with the mod.# is missing,where else can you find the mod.#.
1946Zephyr
Re: older johnson
You should see a quarter sized plug on the powerhead with some numbers on it. Post a pic or two. That will help too.:D
fis
Re: older johnson
from what i can see the plug says j2314394
Re: older johnson
should be plate, on transom mount just above turn bolts. may be covered work grease.
1946Zephyr
Re: older johnson
Yea, sometimes, Johnson only puts serial numbers on the plug. Evinrude however puts both model and serial number there. If you post a pic of it, that would also help narrow down the year. 1955 and older were green 56 -58 were Holiday Bronze. 59 and later were white.:cool:
