FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
i have a 1983 2.5l mercruiser and will not start with key can jump off with screw driver at what i think is called slave solenoid, but i've tried to search for it under this name and can't find it.Please help need to order this part.
You seemed a little unsure, so just to make sure: You have two solenoids. On the top of the starter is the starter solenoid, and away from the starter, maybe bolted to the engine is he starter slave solenoid. The key activates the slave solenoid which in turn activates the starter solenoid. Which one did you jumper with the screwdriver? Just want to be clear.
thanks for your help and to clarify i did jump off on the solenoid not on the starter mine has a bracket coming off the block next to trim pump.
This site has been a great help and i thank everyone for their help.
Last question, did it click when you hit the ignition switch? If not it might not be the solenoid, could be the switch or wiring. Don's troubleshooting will tell which. Good luck.
