Re: Oil Alarm Woes......1987 150HP v6 BlackMax
Ya done good. The small module is he voltage regulator.. First time I ever saw one unmelted
Trace the wiring back on the advance module, disconnect it and remove it.
Remove the oil pump and the long driven gear below it.
Remove the oil pump linkage from the carb linkage.
Disconnect and remove the rotational sensor.
Temp switches have a tan/blue wire only but it is covered with shrink tube. Its the black wire in your terminal block pic. Once you get the alarm and advance modules disconnected there may or may not be any wires left other than the black one. If that's the case, find the tan/blue wire comming out of the harness and hook it up on the same wire as the black at the terminal. Remember, that black wire is really tan/blue.
