rustynutts
Thread starter- Joined
- Jun 23, 2010
- 5
Just bought a 15' center console and the transom mount transducer is shot so I removed it only to find the two holes had moisture in them. I proceeded to remove everything else on the transom and its bone dry. I then drilled out the two wet holes with a larger bit and clean colored, moist wood came out. What should I do next? Does this boat need a complete transom replacement? Thanks ahead of time.
