replacing exh mani blocking plate.
CheapboatKev
Guys..
I am going to end up in the ER from my bloodpressure on this **&&^^%% thing..
I am replacing the blocking plate at the back of my exhaust manifold.
I took the riser off to get me some working room, There are 4 bolts holding this old plate on, or whats left of it..
I got one out, but the 3 left are soooo wasted that they have rounded off, I tried vise grips, nope..I tried that seen on TV Gator socket..what a joke..
They have been sprayed with PB blaster..tapped with a sledge....
Tried filing some new angles on the head to see if I could beat a 7/16 onto it..nope..
Any suggestions, I am at the end of my rope here..
Thanks
CBK
dominic_olenick
Re: replacing exh mani blocking plate.
they make an extractor set mine is a snap on but they work good it twist the bolts right out of almost everything i have used it on
CheapboatKev
Thanks..Is that where you have to drill into the head of the bolt then use the left threaded extractor? if so, there is no way of getting behind the manifold to drill straight on the bolt head..Unless I just remove the whole &#*##^ manifold, which of course I dont want to do:mad:
Bt Doctur
Grind the remains of what is left away and remove the plate,vise-grip or very small pipe wrench.
KRH1326
Sears makes a set of bolt extractors. They are like sockets, except the insides are sharp and spiral inwards. They do work, have gotten me out of alot of tight spots. The only thing is you have to keep firm pressure against the bolt for them to bite and hold.
If you have room, try heating them up, and even while hot, then hit the thing with some pb.
CheapboatKev
Thanks KRH..I am actually looking at those right now on their site...
They dont work with a ratchet? It seems you have to use a box wrench?
I also read where you can heat em up and then apply candle wax, the wax supposedly seeps in and lubes the threads...I think I am headed to sears..more manly than the candle store..lol
KRH1326
You can use them with a combo open/ box wrench, if it is that tight, or I drop them into a socket if I have the room.
Candle may work, never tried it. I do frequently heat old bolts and hit ' em right away with penetrating fluid. Seems to suck in the good juices.
Good Luck
KRH1326
Just remember that you really have to keep pressure on it, onto the bolt, for it to get a good bite.
Ayuh,...
Click on the Sparkplug thread I just posted on,....
I just explained how to remove Rusted, Screwed-up fasteners....;)
CheapboatKev
Thanks guys..
I picked up the extractor sockets last night..about to go hit em with that.
CheapboatKev
Got em out..
Kinda a buffet of all your tips..
Pipewrench got 2 of em..
Extractor socket the other 2..
I bought the torch...but didnt have to fire her up..
Thanks all..Now for my next thread on that dang riser stud..
