Re: The Feel bad for FNG post..
Its like taking out the motor mounts on your 442 and expecting the radiator hoses to hold the engine in place. ;-)
hahaha, for sure.
Who hasn't gone through this process though, in one form or another.
"Its just a soft spot in the deck,
I'll just patch the stringer ,
transom SOUNDS solid."
Or "I stood on the prop and the transom didn't move".
Yeh because the suspension in the trailer takes it up.
Been there and done all of it. Mine sounded solid and didn't budge, but it was full of mushed black pulp.
If you want to save yourself a ton of time an aggravation, sawzall the dang splashwell OFF, cut it so you get maximum access, it will glass back in place stronger than original anyway. Then just use a wonder bar to rip the rest of the transom out. You can't get a new one in there without removing the splashwell one way or another.
The top of the transom will be fine, make 2 slits and remove the top glass from the transom, toss it out. After the new wood goes in just run some glass tape and resin over it, grind it smooth, paint and reinstall the metal guard. You'll have experience with glass and resin by then, its not a big deal.
Repeat this when you find yourself becoming obsessed, "its just an old boat".
Its hard work being neurotic.
