2005 4.3 Merc Exhaust Manifold
kepjr777
Ok, now that I've found a leak in my port manifold...where's a good place to get one? Should I just order it from the boat shop here or look on line? Figured online would be cheaper but I can't find a good source. Also, should I just replace both since they've been in salt water a lot and haven't been changed? They're 5 years old.
linuxusr
Re: 2005 4.3 Merc Exhaust Manifold
See correct one below
linuxusr
I had to replace my manifold this year. on my 4.3 OMC. I was able to get a used one in great condition. So I just pulled the old one off and replaced it. Super easy job, took me about 2 1/2 hours to do it.
Looking for a new one I would only go with a Sierra one myself. There is a bunch on ebay that are cheap. Normally I am all about paying as little as possible. But I was afraid that with some of those you get what you pay for :)
Happy swapping
kepjr777
Thanks for the info. The only one's I've been able to find don't have the right numbers. Mine says 864612 C. The closest I can get is 864612T01. Is that the same one?
Ayuh,... That'll work,....
Depending on the risers, you might need the Open gasket..
kepjr777
Yep, I need the gasket the covers the water inlet and out. The in is restricted. How do I find it? So you're sure this manifold will work even though it says it replaces a different numbered manifold? This one is WAY cheaper than the Merc one that I know will work.
linuxusr
I would give the supplier a quick call to make sure it is, I can't say for sure since I don't know Mercruser parts as well as I know OMC.
Go2Marine's number is 1-800-998-9508
kepjr777
Hey thanks guys, I made a few calls to several different dealers and mechanics. There is no aftermarket manifold for the newer mercruiser. The only replacement for the 864612C is the MerCruiser 864612T01. There isn't a "C" anymore. Maybe someday someone will cast an aftermarket one but for me, I had to pay the Merc price. I went a head and bought em both just be sure. Thanks again though guys.
