so i drained all the gear oil that was in the out drive and put in fresh new gear oil. this is my first time doing this and i saw something i dont think is normal. when the drive is down the blue gear oil leaks through the hole in the lower gearcase and also from the water intake vents. Now when i have water hooked up and running no oil leaks. And when the drive is in the upright position it does not leak either. is this normal? did i put too much oil? 83' omc 4cyl. i/o stringer
