Outdrive Paint
79Rude115
I have done several searches on painting an outdrive and found quite a lot of information but one thing isn't clear.
After the zinc chromate primer...do you put the top coat on after it becomes tacky or allow it to fully cure? Any other tips always welcome
79Rude115
Re: Outdrive Paint
Whatever it says on the back of the can?
Right...that is where I looked first. The can says to either re-coat when tacky or wait 48 hours for a complete cure however, this is in reference to more coats of primer, not top coat. I read several things that said to let the primer fully cure and a couple that said you wanted the topcoat and primer to cure together.
bigbad 4cyl x2
Re: Outdrive Paint
which kind, 2 part zinc chromate, or 1 part rattle can zinc chromate. your attempting either a chemical lay up . or physical adhesion .after the flash window of a chemical layup your stuck with a physical lay up ,sanding will most likley be needed for good adhesion in a physical layup . proper prep is the key . i was looking at repainting my out drive and dreaded it .what kind of top coat ,some top coats need a finish primer for proper adhesion .
79Rude115
Re: Outdrive Paint
1 part rattle can, moeller green zinc chromate
Top coat is moeller arcrylic lacquer base engine paint
Regretably I didn't get any clear coat. Will the rattle can clear from an auto store work? Same procedure as the topcoat over the primer?
bigbad 4cyl x2
Re: Outdrive Paint
id try a chemical lay up ,which is re coat within the allotted time . its hard to sand all the nooks and cranny's
