carthief007
Thread starter- Joined
- May 10, 2010
- 11
86 sunbird with a omc 4 cyl no start no spark...had the boat out 2 mos ago,ran great.rolls over great,getting fuel to the carb.pulled #1 plug and grounded out to block to check spark...none pulled coil wire off,tried the same,same luck,used a test light...clamped to ground on battery and touched -side of the coil,solid light when cranking.removed two gray wires(tach and ESA) re-installed ground...no luck.ran hot wire from + on battery to the + on the coil...same as all before.pulled dist cap and cleaned points,touching good while rolling over...nothing...i used a screwdriver to spread points to get sandpaper in and got a spark there lol.masters help me please
...new points and condenser or go electronic?
