Re: Bad coil or failing power pack??
I'm no expert but I would think you would want to correct the top end issue before rebuilding the carbs and potentially creating additional problems. Assuming your sure it isn't fuel. I've seen the tip here of using a timing light and checking each coil to see if you get a consistent and steady spark on each coil. You can do it on the hose at idle or on the water just be careful as you get up to speed, don't want your buddy to fall out.
