Distributor cap for Mercury 90 HP
kodablitz
Does anyone know where or how to get a new distributor cap for a 1979 Mercury 90 HP? As far as I know, they do not exist anymore. If this is true, is there aftermarket one available? Any help would be great. Thanks.
emckelvy
Re: Distributor cap for Mercury 90 HP
You might try www.ebaymotors.com as I see caps on there quite often.
Also check your local www.craigslist.org boating classifieds, likely you'll find a parts motor with intact distributor on it for less than the cost of a new cap, then you'll have lots of extra parts.
Note that any 90, 115, 135, 140, 150 distributor-model from around '70 until the last run of distributor motors around '79, will have the correct round cap.
HTH & G'luck.........ed
kodablitz
Thanks, I will check those sites and keep looking.
kodablitz
Hard to say by the picture. It is for a Mallory distributor, but I don't know if it is interchangeable with the Merc distributor. I can see it has the side clamps that hold it on. My cap uses a clamp at the base to hold it on. If it is the same diameter and height, it could possibly work. I will have to see if there is one locale and take a look at it. Thanks
emckelvy
That's a cap for a Mercruiser Chevy Inline Six. Doubt it would work on an outboard.
Didn't find any used or old-stock caps on eBay, however, did discover that aftermarket caps are available from "Repair Inc", part # 994-4841. Here's a few places I found with lower prices for the cap:
http://www.glockworld.com/item/371224__Marine_CDIE_MERCURY_DISTRIBUTOR_.aspx
http://www.midwesthuntersoutlet.com/item.aspx?PID=371224&w=PQ+JDyOLrQE=
http://www.hinklemarine.com/outdrives.php?cat=IG
http://www.magemarinestore.com/cdimeredicap.html
http://www.blackbearsportinggoods.com/Mercury_Distributor_Cap_6_p/ellcdie9944841.htm
Any of the above are considerably cheaper than the last price (around $140) of the OEM cap, when it was still available.
It's still not an inexpensive part, but compared to the price of a new motor, a bargain if it gets you back on the water!
Have Fun!............ed
kodablitz
Thank you very much. This helps out a lot. That's the thing about boats and all recreational stuff, is they are expensive to keep up. Thanks again.
