Purpose of Purple?? 55 HP 559HD
landlock
Hello guys! I hope everyone is having a great summer at WOT!
My manual shows a purple wire coming from one of the Ac post on recitifer and then it pass on to my block term and on down the harness and is tape off at the ing. My question is what is the purpose of this wire and should it be showing 12.5 volts? I put a new choke selenoid and a new ing switch and she turns over but will not start!!!:mad: spark at both ends,flywhell off points look good strator looks and test out good recitifer sparks when i hook up the neg term!:confused: Help frank!!!
jkoppe73
Re: Purpose of Purple?? 55 HP 559HD
purple is usually reserved for a tachometer
huskerdaninva
In my Glenn's repair manual the 55hp motor w/ magneto does not use the purple wire in the harness at all. If you have a rectifier on your motor and alternator the purple wire should be the lead for a charging indicator (green) light (Idiot light). Pretty sure indicator light was an option and would have to been ordered/installed by a previous owner. Sounds like your set up never had the indicator light installed. Might want to do that to maybe give you piece of mind. Hope this helps...
landlock
How sure are you about that,because I was thinking generator/alt.
white is what I was thinking was tach??/:confused: Thanks for your input.
landlock
Now that makes sense! I think I will do that. Thank you!
Any ideal what would make the recitfier spark when all the ac and pos+ is wires are in place and i go to attached the neg- to it's post??:confused:
huskerdaninva
Glad I could be of some help. As to your other question, I'm not 100% sure just exactly what you are referring too. Might I suggest posting a picture or two to give others who might be better able to help you get a handle on what your problem may be.
I'm not an electrical guru, but if you have any connection producing a "spark" when connecting another terminal something is not good. You ought to disconnect your battery before attempting any service as you could accidently burn up some ignition components depending upon your motor etc. Good luck and let's see some photos!!
jerryjerry05
Purple with 12.5 volts is a power lead to the lights in the instrument panel. Grey and purple are used for the tach.Got grey?? Over the years the code changed about as often as they changed design.J
landlock
Thank you very much for the info and pics are on the way.
landlock
Okay I see that was a option for the lights for my engine. thanks for the info,
know i just have to figure out why she just turns over and want start the seloind open and closes the choke that i installed. and the wiring to the knew 6 post push to choke works right and is wired according to the book,but the rectifer spark when i connect it.:redface: Thanks JerryJerry
