Re: New to outboards, need help
http://www.boats.net/parts/search/BRP/JOHNSON/1972/85ESL72R 1972/EXHAUST HOUSING/parts.html
part #53 (steering assy) will have to be replaced, and if I can't find a used one (discontinued by manuf.) I'll have to bring it to someone who could weld re-enforcement pieces on each arm.
The starter is shot and the one I got from Ebay yesterday fits perfectly just like the old one...except, of course, for the gear which is smaller in diameter and doesn't reach the flywheel teeths (I did take the time to make sure that the Ebay seller had the one for my engine model). I going to try to return it unless you guys know a marine starter rebuild shop where I could have them change the gear to the right size and save myself some time.
Also I found out why I couldn't tilt the engine. The bolt (part# 16) which goes through 23, 1 and 24 is completely frozen with 23 and 24. I tried everything I could to get that bolt out so I could clean and grease it but nothing. It's like 16,23 &24 are welded together. I also had to cut each shock absorber arm which were also "welded" to a heavily corroded pivot pin (50) which had also to be cut off hoping that I could punch it out (not happening either).
So at the end of the day, nothing got done except putting the engine on a lift and cutting corroded metal.
I purchased the boat (fishing type) and engine for $550. The boat is not bad at all, good hull etc. however, I am starting to wonder if it is worth spending money to get the engine back and running. I heard from a guy in a boat shop that "those old engine run forever". Probably, but at this point in time I need a few parts and finding out that a few are discontinued by the manufct. This is starting to worry me a little.
So my question to you guys is the following: Do you think it would be wiser to save maybe around $700 and get another used engine which would be a little more recent (parts available) or would that money better spent buying new parts for the old one I have (Johnson 1972 85HP)? I don't mind rebuilding this one slowly but with more and more obsolete parts for this 1972 dinosaur, am I pouring money into a hole that will get bigger and bigger as the parts will become more scarce?
Very much appreciate your advice or comments. Thanks
