Re: TLC for 77 Skeeter SS-1
http://s827.photobucket.com/albums/zz191/usmc0386/
Here is the link to some pictures of the project boat. A few things that I have questions on:
Why is there a hole in the middle of the deck and does this wood look like it needs to be replaced?
The trolling motor outlet is old, if I buy a new motor does it come with a new or do I have to buy it? And what others things are required to run a trolling motor?
The boat doesn't look like it goes together. The liner and hull seem to be a bit off and the previous owner just filled it with some type of chaulk instead of getting the right stuff.
I know there are two pieces, so if the top is wrong what is the best way to get one that fits?
I noticed that there was some type of drain or inlet spout on the right side of the hull toward the front and back. This is for the livewell I am guessing and how should they be ran? I noticed that everything has been plugged with some type or another chaulking which doesn't seem right to me
.How do I make this correct?
There are two plugged drains or outlets on the back of the boat, what are they for and should they be plugged? The boat is also missing the plug so its a good thing i didn't try to fish the boat this week!!
The next few pictures are of the mess they call the wiring!
I don't know what goes to what. The mess of wired under the dash is hard to figure out what does what. I do I start to remove this mess and clean it up? Also, the battery compartments are filthy, how do I get it clean? As for internal fuel tanks, are they against the law now or now? The rod holder does not fit anything over 6" poles, is there a way that I could make my longer poles fit and organized it more? Plus the carpet in there and several other compartments smell horrible. Should I replace it with some more carpet after fixing the compartment seals or try to finish them with something else?
How do I know what gauges I need and don't need, and what other options could I put up there? There are 3 acc switches, 1 fuel switch, and bilge pump....what options do I have there?
The last few pictures are of the engine that they have mounted. Several local guys here said it was too big for a 15ft Skeeter but I have seen 100hp+ on the same size boats. I have been trying to find out what the max hp I could put on there but nothing has seem to work to well. I guess I could always call the mfgr!!! If the transom had electric trim and tilt would that better support the motor without damaging the transom?
I know that I have a lot questions I have help re deck boats and other things but this is my first boat. So any help or advice would help. I have been cleared hot from the boss to invest couple hundred each check into it until it Spring time again!!!
One last thing gents, I want to get this thing painted a hunter or forest green with flakes, whats your takes on the carpet? Thank you once again!
