I have a 1986 Chaparral V6 4.3 MerCruiser, Thunderbolt IV 175 hp..
Serial B579723
Carborater is a two barrel McM 175 3304-9565
Working on the boat I replaced the head gaskets, intake gaskets, riser gaskets, and adjusted valve trains, by taking the slack out of the push rods, then turning the nut one complete turn. Have the timing set 8 degrees. The boat will start up and idol ok. No problem starts right up, after revving the engine it will rev as long as you keep the rpms up then it will die, back off the throttle.
I took the linkage off the carborator started the boat, and manually gave the boat gas, by revving up it still dies..
Please advice
Serial B579723
Please advice
