Re: 4.3 v6 dies after reving
Start at number 1 turn engine by hand watch until valve closes turn a little more now on base circle loosen nut while gently lifting up on rocker at valve tip end once you have a gap sloowly tighten nut till you just touch valve again stop do all the same then turn 1 half turn to set 20 thou lifter preload your done
