need homemade brew for applying decals
crazy charlie
Im replacing the decals on my o/b engine cover.anyone have a home brew to aid in the application of decals before I go and buy the spray??? Thanks Charlie
Jeep Man
Re: need homemade brew for applying decals
Water and a little (and I mean a LITTLE) dish soap in a spray bottle. This allows you to move the decal and also squeeze out and air bubbles before it dries.
Stachi
x2...A short squirt of it into a 32 oz. spray bottle after filling it with water..(less foam ) ....dry fit decals , and draw a level line with a pencil where you want them to end up, wet the surface evenly and apply the decal.....as longs as the surface is wet with a very mild solution of dish washing soap you can move the decal, set your decal to your line, blot the excess solution surrounding the decal with paper towels, and squeegee any air bubbles out..carefully...start with very light pressure to the decal from the center towards the edges while keeping an eye on the level line..flip the pencil over afterwards, and erase the pencil line... NICE ! :D
crazy charlie
Thanks.Do you mean a few drops or a small squirt??
642mx
I've always used Windex. Spray a fine mist on the decal, move it where you want it, and then use a credit card to remove the air.... and finish with a hair dryer or heat gun.
Stachi
small squirt...after you squirt it in , put the sprayer head back in , and tip the bottle back and forth until it mixes...test the squirt pattern on something other than the work area , you want a wide misting type of spray...think of it as a film of soapy water you want to apply... its ready when you see very small bubbles on the test area...
Fireman431
Per the DecalMan web site: 2-3 teaspoons per quart size spray bottle (think window tint solution).
Stachi
I am going to recomend that you not use any heat...it may shrink or distort the decal... squeegee it out after blotting, let it dry for a day and it will look great...Windex will work , just kinda expensive to use for this...and it contains some ammonia...not sure how this will effect the outcome..I have used Windex and a razorblade to remove pinstriping from automobiles... , just a thought...
Stachi
yup , a short squirt...one missippi two missippi...done...add the soap to the water...or it will foam out if you add the water second... :cool:
Stachi
by the way ,....we are expecting before and after pics....lol :D
dlngr
Windex will NOT work with some decals,and I have seen some decals that specifically say NOT GLASS CLEANER!. Better safe than sorry and stick with the dish soap!
642mx
Really? I've been doing it for years with all kinds of decals and never had a problem. Everything from vehicle emblems to window tint... and its always worked fine.
Stachi
I think it is the ammonia...I use glass cleaner everyday to remove inspection stickers from automobiles...it really cuts the adhesive...use dish soap...you will be glad you did in the end
Stachi
642 , stop wasting your $...dish soap works ....and cheaper !
smokeonthewater
I have always used ONE teaspoon to a GALLON of distilled water.
lakegeorge
Dish soap has worked for me many times and it's safe. Don't use anything else.
Jegomes
the only thing better then dish soap is no tears baby shampoo. Its way milder then dish soap and dries with less residue. It also has a neutral PH balance so it will not effect the decal in the long run.
vscgraphics
Try this :
1% Ivory classic scent dish soap,
15% 91 "proof" isopropyl alcohol,
84% distilled water
Thanks
Joe
VSCGRAPHICS
Woodbinekeith
If part of the question involves removing old decals, there is a product on the market at home reno stores called Goo Gone. A fluid that you can apply with cloth to the top of the label/decal etc. Let it sit for a bit and it softens the glue on the back side of the label/decal. With any luck it lifts up with a finger nail but at times is takes a little more goo, some rubbing and perhaps a razor blade. It is very effective and doesn't affect the fiberglass. A razor blade can mar the surface if not carefully done.
