need homemade brew for applying decals
scca vette
Re: need homemade brew for applying decals
Another vote for water with just a cople drops of soap!
If the decals have a paper (premask) face that is to be removed after installing the decal you will want to use a lot of the soap/water over the top of the premask paper to help it release from the decal.
RicMic
A professional that installs those huge vinyls on police cars told me, after some nagging, a few DROPS of JOY dishwashing liquid and a teaspoon of isopropyl alcohol to a quart of water. Spray it on both sides, the surface and the vinyl and work from the top down. This is what 3M recommended and they make most of the quality vinyl. Its best to work in warm temperatures, but I wouldn't use a heat gun for applying, its to easy to over stretch the decal, but it is much easier to work if the surface and decal are say a 100 degrees or so. I do use a heat gun to remove decals, get them good and warm and they will usually come off clean and in one piece.
JimS123
Sounds like we may be talking about different things here. Are you applying waterslide decals, or vinyl stickers? I've used the recommended soap solution for "stickers" and had good luck, but I've never had soapy water work well with a true "decal".
If you are using the old fashioned OB motor lacquored water slide decals, then dishsoap is the least of your worries. There are only a few sources for these reproductions and some of them are very thin and tear easily. They don't lend themselves well to compound curves. Before you even start, coat them with a clear acrylic spray like Krylon. Then cut them out of the paper backing because the overspray on the paper will make a mess.
Use warm (not hot) water to soften the glue...I use about 90F water. I prewet the engine part with hot water first, then slide the decal off the paper onto it.
Let it airdry for 1 week minumum before topcoating. Use a clear enamel from a hobby shop and brush it on the decals, extending the coating to about 1/4" beyond the decal. This will best duplicate a factory job. If you chose to clearcoat the whole engine, be sure your topcoat is compatible with both the engine paint and the Krylon on the decals.
The larger the decal, the harder it is to apply. I have applied single decals to a single flat surface and not bothered to precoat the decal. The hardest ones are the old square tank outboards, where the decal wraps around 3 sides of the tank.
Frank Acampora
Here are a couple of sticky types that were applied using Windex:
