Watermann
- Joined
- Jan 12, 2013
- 13,854
:welcome: to iboats Fish Laugher!
I sure hope you plan on going out on the gulf side with that open bow fishing boat things could get a bit dicey if the swells pick up. Be sure to rinse your boat, flush your motor and trailer very well after being in the brine if you want her to last.
You could get by with a 6 HP on that for trolling but if you're wanting a kicker to use as a backup motor then I would go with a 9.9 HP if you wanted to get in against the tide then it may take a while. SOme guys are able to get by with direct clamping a long shaft kicker on the transom next to the main motor without needing a bracket.
