1988 Rogue 2420
tpenfield
Wow, you are really having to fight every inch of the way. Sending happy thoughts :)
tpenfield
well..... no turning back now....
the point of surgury
the first hole.......
used an 1-1/4" hole saw for the first side...... that way I can move the hole up/down/fwd/aft as needed.
some of the flotation foam will need to be removed as the hole is centered on the top edge of the foam
that was it for Tuesday...... On to Wednesday
get home late
however some more exhaust tubing arrived (its just 316L sanitary elbows and tube with a polish folks). two elbows, $25 each from a plumbing supply house
That came out real nice
it will be better when its actually mounted.... gravity has it slightly twisted, and it wont sit flush on the hull yet, however should tonight. then I have to hook up the H-pipe dumps and mufflers to the tips. a bit of modification will be needed, and I need to give up on the captains call as there is no room in my boat for the H-pipe with the dump elbows, mufflers, and captains call....
going to list them on fleabay - new never run Chris Craft 28 Corsa captains call diverters from a 8.1..... may get enough for gas money.
got the hole opened up
using my patented foam carving / removal tool
then using my patented helper hands
I now can look inside to see how I need to modify the pieces
Exhaust outlets mounted (pics tomorrow)
Mufflers will be modded tomorrow
Found a new set of B8 props some one in the Fox Lake are of Illinois bought by accident...... $275 plus $24.99 shipping.
New set would be $650...... Score
Modified exhaust elbows - took the elbow off the muffler
had to be creative with the elbows and clearing the internal longitudinal stringer. hence the elbow clocked at 45 degrees.
both sides installed now
Had to work Saturday for a military project.....
so, didnt get to work on the boat until today.
had the mufflers modified during the week, and the first elbows shortened.
My polishing guy at work is busy polishing the bow chafe plate and the anchor door for the Lexus LY 65 yacht..... so he couldnt get to my "g'ment" job
so....
take a pair of exhaust elbows scratched during motification.
start addressing the welds with 2" grit discs
first coarse..... then fine
Move up to 600 grit (side by side for comparison)
0929191058_resized.jpg0929191117_resized.jpg Then move on to 800 grit
then 1200 grit
then 1500 grit
then 2000 grit
then 2000 grit
then 3000 grit
Then polish
after polishing, one must stand on their head to install mufflers, elbows, and hoses
and yes.... my feet are black from polishing compound
0929191648_resized.jpg Just need to get a 45 degree barbed elbow for 1" hose and 6 hose clamps
you can see the sweat and goo from my arm as I leaned on the H-pipe.
Now I can move on to installing the battery switch, the bilge plumbing, the bilge vent plumbing, and the batteries.
Is this the only flex joint in the exhaust
fetch
tpenfield
I think your exhaust is worth more than most boats cost :D :thumb:
the wife's exact words were..... but no one will see it, why do you care if its shiny
my reply was "the same reason you care if your purse matches your shoes"
500 degree 4-ply nomex silicone hoses are pretty squishy and flexible. a lot more flexible than 250 degree marine exhaust hose (and the same cost)
the original motor had 1" between the y-pipe and the elbows running a factory balance on factory cheap isolators
this is a fully zero-balanced big block, with brand new higher capacity isolators and two hoses on each side with a gap. I doubt there will be any movement, yet if there is, it will be fine.
Understand what was and what is now, and what kind of hose. The gap between elbow to Y-pipe is on the same axis, a little twist is not going to do much. Yours extends across both mans to each side, like maybe 7 feet. The motor won't move but the hull will. Hope I'm just a worry wart :noidea:
the hull is between 1/2" thick at the front of the opening and 3/4" thick at the back of the opening where the tabing is.
Its over 3/8" thick where it meets the cap which is 1/4" thick
I have bigger problems if the hull moves. that means I hit something.
minor update....... the Admiral is away this weekend..... the plan was to have a get together Saturday with a few buds and have a bonfire.
however the tropical storm went thru, made it a bit wet. in stead of fishing earlier in the day, a few of us did electric karts to shag off a hang over.
had the guys over last night, and to get the fire started, used some napalm.
clean up today, may get back to the boat after the Packer Game
No one will see this post with the new forum format unless they are subscribed to it.
that line is specifically aimed at iboats_tim and Kiter007 because this post will not appear in the new format anywhere
I have almost stopped getting notified by email of new post, I'll get one that is more then a day one time and another it will be 8 hours. Once here I can still get to the messages in the inbox, but that's about it
