LX Kid
Ensign
Thread starter- Joined
- Sep 5, 2008
- 993
Got out on the water, decided to try another spot, tried starting and "no power!" Battery cable tight and then found that the thermal switch had faulted. Reset thermal switch and started just fine. (Had to reset several times during the morning of fishing.) Noticed the amp meter showing a charge of 16volts and the tack pegged and quit working at max deflection so I pulled wires on tach but it still pegged and suspect burned out. Headed back to the ramp and engine spit, sputter and all guages jumping. Pulled positive cable off battery, to see if alternater was the problem and no change in the symtoms. Anyone have any idea about the electrical problem? Thanks
