18' Starcraft Starchief OB Rebuild
Gibbles
beverages were kept very chilled :usa2:
Running at no wake/low wake speeds it just sounds big, nice rumble coming up, but smooth, really no vibration noticed (unlike my 2 & 3 cylinder mercs), almost V8 rumble.
I'm very happy with it.
I did get some looks on the lake, stares ect :hat:
I was totally the oldest thing on that lake :first:
Watermann
Oh yeah! Man she looks great, I bet people were gawking at her, she looks like a million bucks :thumb:
To plug the holes in the transom, I used 1/2" dowels when I had to plug unused holes. Bevel the insertion end and then cut a groove around the dowel with a hack saw blade, smear with gorilla glue and tap into hole.Only make the dowel 1.5" long so you can set it in just to the wood and fill the outer part of the hole with JB weld and once hard sand it smooth. I then use a piece of cardboard, put a hole in it and shoot a few light coats of matching paint on the repair.
Next time take a vid for us so we can hear "da fridge" rumble and snort. :D
dozerII
Congrats Chris, the splash was a long time coming. Ya video of the fridge that's what we need.
Gibbles
Multi quote feature is broken... :)
When I first fired her up she smoked bad, I knew it would subside after a while.
I had the same problem in the tank, but she has been hibernating for who knows how many years in that field (those who followed the craigs list starcraft thread may of saw it, I had satellite photos!).
Again thanks Dozer, your V5 worked out well for the both of us, I'm not sure if you flipped her yet but any time you need another exported ;)
FIL kept asking if she was 50:1,a big smoke screen.
I kept saying: "She will clean up after a good run"
I was worried about the thermostat, I hoped it would not fail on me, there is an overheat buzzer I lost a screw on so it never got hooked backup, plus the whole "noidea if it even works" thing...
Once she got up to temp and the smoke screen cleaned up, I noticed the water coming out of the exhaust was steaming up as it hit the cool water
I never could get the boat to level out, pretty much right as it was getting ready to plane it felt like the prop was slipping.
I thought the hub was toast at first, but then I saw the prop start it's way out of the water... :facepalm:
Waterman; thanks for the tip, I'll give it a shot this weekend if all goes well, and get the engine lowered.
I recall there being an issue with the massive size of that engine and my splashwell... raising was a way around the issues...
My camera does have the video option, I'll try and get a good video the next time around :)
jbcurt00
Nope, just not the same
Looks great!!
Oh yeah! Man she looks great :D
Congrats Chris, the splash was a long time coming..
Click the 1st post you want to quote, let the reply window open w/ just the 1 quote, then go back up & hit "Quote for each post you'd like to quote. When you've selected all the posts you want to quote, look to the upper left corner of the screen. The Post Reply to button has changed colors & now has a number in parenthesis at the end. The # is how many posts you added to your quote list.
Click that Post Reply to button and all the posts you wanted to quote will be dropped into your post. It will ONLY post them in the same order they were posted originally. So I just cut & pasted your quote to get it to be 1st in this reply.
BTW: When you click more then 1 quote button, the "Quote button changes color. If you re-click the same "Quote button, it changes back to it's normal color & is no longer included in your multi-quote post.......
Weep'n Willy
Looks really great on the water. I bet you got several stares . . . of admiration of course. Not every day one sees a boat of that vintage looking great on the water. Congrats on the splash.
dozerII
Your welcome Chris, I still have the V5 to do maybe this winter, she will get a 140 Merc TOP for power.
Gibbles
Glen- I look forward to seeing that rebuild :)
And this weekend I managed to lower the engine using the wooden dowel trick worked great.
I picked up another quart of west system epoxy, I put off ordering the other stuff and decided I needed it for the lowering, so I bought local.
I let the epoxy thicken, then cut some spirals in the dowel, drilled the old hole out to clean the sealant as much as I could, recoated the hold, and inserted the dowel.
Then with a fresh batch of epoxy I thickened with sawdust, allowing it to soak in, then let it sit till it got nice and thick, and capped the top of the hole off holding it in with tape.
Then I lowered the engine, centered as perfectly as I could and drilled the new holes.
Then with a fresh mtdew can cut in half I mixed another batch, while nice and runny I used a dowel with groves cut in it to spread the epoxy around in the hole.
and repeated a few times while the epoxy got nice and thick, finishing off with a nice thick coat inside of the new hole.
Following day once everything cured I raised the engine via floor jack, took a drill bit to clean off the top of the old hole, mostly ensuring it clears my transom protector/ stiffener that the boat came with (drilled into the repair to ensure the guard and the repair were separate) then put a light coat of epoxy to cap the repair, and sealed into the remaining with 5200, taped over and lowered the engine again.
One final coat of epoxy into the new hole, and I started work with the tilt lock.
Previously I had issues with the tilt lock, pretty much I was unable to lock the engine in full tilt due to the size of the mini fridge, the top of the cowl would hit the splash well preventing a full lock,
As a workaround, it was decided that the engine needed to be raised anyways for best performance + to clear the splashwell.
I also picked up a "trailering bracket" that was an option from the factory, it holds the engine at a slightly lower tilt for travel down the road.
Well after my first outing last week, It was noted how low the engine already sat, and it was decided that the boat would need to be backed into the water with the trailering bracket removed but in full tilt lock (trailering bracket would be a pain to remove while inside of the boat), due to how low to the ground the trailer sits, the skeg being in jeopardy...
So once I lowered, reminding my self of the previous issue, I first confirmed I can still get a replacement tilt lock, then I pulled it from the engine, and drilled a series of holes where I decided the material would get removed from.
Then using my diegrinder I started cutting, and then finished off with a stone bit.
reinstalled, and confirmed that my now huge channel won't cause an issue unless the engine bounces, allowing the cowl to slam into the splashwell... :)
another side affect of the larger channel, raising the engine all the way up now auto engages the tilt lock, prior I had to manually push the lock into place via reach around :lol:
I noticed on the replacement tilt lock kits available, it comes with a bracket for the other side of the engine, it serves as an additional limiter to prevent the engine from going to high.
So maybe later on I'll see if I can't fab up a bracket that will prevent the lock from going to high, into the splashwell
Watermann
Nice work on the fridge drop, the attention to detail should make it a lasting repair that's as good as new. :thumb:
The CMC tilt and motor toter on my OB boat keep things out of the dirt, I take it that heavy 140 doesn't have TnT?
Gibbles
no TnT
I did find a TnT motor listed for nearly $300 nib, I would need to figure out how far that would get me along tho, + it's a lil expensive... :)
GA_Boater
With all you're going through, Gib, now I know why Chrysler is owned by Fix It Again Tony. :lol:
Watermann
You get everything ironed out Gib? You probably got her back on the water and are enjoying the Fridge rumble. :lol:
Gibbles
Well i got the tow rig all fixed up last weekend (new cv, wheel bearing and ball joints). Engine is lowered, nautolex installed on cabin floor, and i installed a tale tail on the fridge. The plan is #2 outing this weekend, how ever the wifes car needs a new radiator... So thats ordered, if it comes friday i start on that and try to finish by saturday for some friday boating... Also traded in my vintage flip phone for a droid... Seeing some minor things with posting, but pretty fun device
GA_Boater
Hope the rad comes in early, Gib. What ring tone are you using on the 'Droid? "Shaddup, I'm a boater" followed by "Anchors Aweigh"" :lol:
Gibbles
Having issues editing :lol: *Sunday boating* Woo i joined the 21st century!
Gibbles
I should write an app with a mr t voice saying " you cant talk to me like that, i own a boat foo!"
