Bonaventure
- Joined
- Jul 3, 2016
- 167
I will try to post a photo soon.
I am using a 2 hp Johnson 2 stroke, which only weighs 25 or so pounds.
The block part of the Mount Extender is the same thickness as the as the existing plastic pad on the mount, 1 1/4 inch. The other dimension determines how much the motor will be raised. The Block sits on top and has a 1/4 inch piece of plywood epoxied to both sides. The sides extend down each side of the plastic piece about 3 or 4 inches, they are shaped to fit the Intex Mount. Then I drilled through with a 1/4 inch drill and passed the bolts through. I positioned the bolt holes to miss the clamp of the outboard.
The item looks like an inverted napkin holder.
