Woodonglass
- Joined
- Dec 29, 2009
- 25,930
I'm gunna recommend that you post this on the general forum, the chat forum and then technical forum. I'm sure a LOT of people could benefit from your knowledge of circuitry!!!
Great job on the float sensor.
Would work great in a glass boat but copper isn't too friendly with tin hulls.
Do you think aluminum tubing would work for that application?
I got two of em And I'll measure em tomorrow and take pics so you'll have the measurements.I presently have a brand new Moeller 6 gal plastic gas tank. And while it is new, I am not so sure I like its design. Does anybody have the dimensions for the older typical 6 gal metal tanks that the Evinrudes and Johnsons use to use? I 'd like to know that actual footprint of those older metal tanks to see if it would fit in the area I have reserved for the gas tank in my boat project. I see a lot of them are on EBay and was looking at them. But not one stated the dimensions of the tanks. Anybody have any ideas?
I'm with Woody that float sensor needs shared. :nod:
I'm barely an amateur hobbyist at electronics and I'd say it's simple enough that any fool (points finger to self) with a soldering iron could knock that out in no time. Even if it was just following the schematic and putting it together on some protoboard. (what I may do)
To show my gratitude I ran out and measured one of the old metal tanks - roughly 11.5W x 18.25L x 11.5-12H including the handle. Had to eyeball the height to the tape measure so YMMV
You never cease to amaze me GM, first its your clamp inventory, and now this, a auto bilge circuit. Nicely done sir. I will need to investigate to find a source for the electronic components. Quick question, is that circuit board pre-made or did you etch it yourself?
Glad you got a bit of sun ! I know we have had our share of rain and then some over the last month .. My neighbors pond will over flow and it goes like a river right through my boat work shed area .. About 3" deep !
Motor and glass work looks great !
