gm280
Thread starter- Joined
- Jun 26, 2011
- 14,605
I know that feeling, by now I'd be content with plankton soup
What grit you going to be using on the primer btw? And how much smoother grit near the edges??
Red, I use 320 grit initially to knock down the raw primer with a DA sander and then come back with 400 wet and dry hand sanding for a final before painting. At 400 grit, it is really smooth and still allows the paint to adhere to the primer very well. Then I will shoot a few coats of paint followed by a few coats of Clear to seal everything up nicely. And probably even 2000 grit wet sand the clear before buffing it all out. I also could wet sand the paint before shooting the clear coats if it looks like it could use it. I've done it both ways and it really depends on how the paint coats look before shooting any clear. I really need to get back on it now as well. Spawning crappie season is not that far off.
