Thanks for the feedback folks... I always appreciate everyone's ideas and suggestions. Whether they give you a direct solution, or simply trigger an idea, they are helpful.
Did you ever do something so totally stupid that the only thing you can do is laugh? Well I did something that completely stupid and I am going to post it here because you all deserve a laugh as well.
If you followed this thread for very long, you probably remember me stating numerous times about installing carpet, and I know I mentioned this a few times in other threads as well. Any time you install carpet you absolutely have to make sure the grain of the carpet runs all in the same direction. If you remember, I actually used chalk and made arrowed lines on the back side of the carpet in a not the long ago post. And that is because if you don't install the carpet in the same direction, the color will change...
Well yesterday, I was doing some little things once I found out I needed smaller clear heat shrink tube for the wire labels. So I decided to carpet the front deck storage lid. I cut the carpet from the roll and made certain the arrows were going the correct direction. I then used the Permatex spray glue and covered the carpet and lid in preparation to carpet it.
Once I sprayed both parts, the arrows were no long viable. So I went to the roll of carpet to get the direction of the arrows again. Don't want to screw up now. Well It went on very nicely, and the glue and stainless steel staples did a nice job getting it all covered.
I was pretty proud of the job. Then I put it in place on the deck. OMG, It didn't even come close to matching. I put the carpet on 180 degrees out with the rest of the deck carpeting. The only thing I could do at that time was laugh...
As many times as I have warned others about such things, I am 10000000% guilty of screwing up myself. Take a look at the pictures and view a perfect example of why you need to make sure the carpet runs the same direction. Sure hope I can get it all back off the lid and have enough to recover it again.
I'll try to get in right the next time....What else can I say.
ound:
ound:
ound:
ound:
ound:
