classiccat
Thread starter- Joined
- Dec 20, 2010
- 3,412
CMC Unit Mounting:
I had an "oh crap" moment a few days back.
I 1st mounted the mirror-polished faux motor pad using 1/4-20 bolts that were slobbed-up with "pelican poo" (5200).
The admiral pitched-in and helped man the impact driver from the outside while I was inside.
We got the CMC hung and after cleaning-up the residual 5200, I snapped a pic.
When sat down inside to check out our handy-work, I zoomed-in, I could clearly see that the pad/kneebrace bolts were hitting the CMC!
Stupid-me for not dry-fitting!
This was pretty late in the evening so I had to dismount the CMC and pull the lower 4 pad bolts and clean-off all of the 5200.
TIP: denatured alcohol is waaay better than acetone for clean-up. WARNING! I wouldn't use alot of it near 5200 that is drying...but for cleaning off drips, tools, etc.
The next day, I dry-fit the CMC (with the 4 pad bolts still pulled) and drilled 4 shallow dimples into the backside of the CMC (from inside the boat) to accommodate the pad bolts.
Now it fits like a glove:
I used the highest setting (upper hole) based on measurements, the anti-cav plate should be 2" above the hull bottom when using the motor's lowest setting (highest hole).
The CMC has over 6" of setback...probably closer to 7" in the vertical position so my gut is telling me that I parked it in the appropriate spot.
