zool
- Joined
- Aug 19, 2012
- 3,433
You got about a week before the first snowfall, right? It's been getting mighty cool at night here. Gives you a little pep in your getalong.
Man I hope not, seems like its all happening early this year
I'm voting for a nice warm winter, I had enough snow and ice last year!
Update:
well I finally got the remaining glass in the midship area done, capped the 2nd stringer with 2 layers of eglass, and a few tabs of 17oz to tie in the bulkhead ends...I have to pick up a course die grinder bit for the limber holes, and sand down some nibs.
Just needs some epoxy paint, the brackets for the water tank, and a little plumbing, then this deck section goes back in.
Today we're gonna try to finish the walls on the shelter and get ready to set the ridge beam![]()
So that 1708 will lay down flat on a 90 degree angle/top of the stringers? Then I guess it's about really wetting it out, no bubbles? Neat! I'm definitely gonna try that out.
degrees under the bubble so hopefully yes there is another month for us to glass.
What are your thoughts about foaming under the deck? I'm still in a pickle on that concept.
If I had factory foam, I probably would have put it back in, but mine didn't, and is set up with redundant pumps and limber holes, so I put it back like that...it would take an awful lot of foam to float this pig...I mean rig....re-engineering with foam is not just adding it, its adding it in the right places, at the right amounts....
Im cool with a liferaft, epirb, and a stash in a ditch bag.....oh, and insurance![]()
Now that actually brought a major laugh to my face/mouth. Still laughing....I like the "stash" part too! :** I needed that laugh today thanks!
Stuff happened!
Looking good. I will need to keep the garage floor enamel in mind. I have a lot of interior to paint. Does it level well?
Nothing like a fresh new coat of paint ! Even if it is up under the deck ...![]()
That midship compartment is looking pretty spiffy! Flexibility is the first thing to go.....or...wait a minute....maybe it's the mind that's the first thing to go...I can't remember...
It goes on thin, with 2 coats max...I just used a brush, and it didn't leave brush marks. Its NOT rated for vertical surfaces, but that's on concrete...ive had it vertical on the tank area all winter with no adhesion problems...it comes in a base to be tinted in any color, or white and a few grays off the shelf. This was the one part water based, it comes in a 2 part also....
http://www.behr.com/cma/Behr/Marketing/Products/product_sheets/900_PS_R411.pdf
For Tint Bases - Do Not Use Without The Addition of Tinting Colorants
