Hydra Sports 1650 Key Largo
Status
Not open for further replies.
rkmnoles
Does anyone have any knowledge or review of a 1994 Hydra Sports 1650 Key Largo? I have an chance to buy one and just need to know what the quality of this boat. Thanks in advance.
ezmobee
Re: Hydra Sports 1650 Key Largo
What really matters is what condition the boat is in now. I wouldn't buy a 1994 Grady White if it wasn't well maintained.
rkmnoles
I fully agree. Living in central florida I see my share of junk due to sun and moisture. I check decks, transom, equipment, steering, compression and the list goes on. No extra holes just the dull gelcoat and a bird nest of wires in the console due to the addition of trim tabs and other items. I will organize that and neatly ziptie them.
jbwilli
I believe I may have looked at the 1994 Key Largo you are referring to. ID # FL 6643 HV?
The Hydrasports 1650 Key Largo is a great small boat. These were manufactured for 25 years, the last ones being produced in 1998. I have one these 25th Anniversary Models!
The Hydrasports Key Largo is a superior built boat with NO wood and a combination of fiberglass and kevlar composites.
16'4" length, 6'10" beam, draft of 11" (motor up), 1076 lb dry weight (no engine), 115 max hp, 30 gallon integral tank.
Also on board oil tank! This boat is built like a tank!
All stainless steel hardware and paired from the factory with salt water engines and equipment. The hull is a modified Vee with a Carolina Flare for a dry ride (anyone who says this boat rides wet either has not ridden in one, or they had it trimmed way out of shape while running into high seas and a stiff crosswind!). Any small boat will get wet if you don't trim and run out properly! It has a large round livebait well and 2 large square dry storage boxes that can also be filled as livewells! Up front, there is a HUGE bow storage area! Horizontal rod storage compartments in both sided and vertical rod stows on both side of center console!
My 1998 has OEM power trim tabs and a power jackplate. These two items really make this boat's ride go from normal to superior! Yes, with the modifed Vee, this is not a true flats boat, but it is a great compromise! It rides way smoother than any comparable sized flats boat! You will be riding smoother and faster in the deep water run out to the flats, while the flats boats are having to slow down to keep from getting their brains beat out! You can go offshore to oil rigs and reefs on normal seas days - most flats boats cannot! The compromise in skinny water ability is very minimal - you can get within 2-3 inches of the same depth of where the flats boats go!
I love mine! I meets my needs perfectly. Light weight, lower horsepower, easily towed with smaller vehicle, economical to tow and operate! I fish both salt and fresh water. Rated for 4, but performs best with 2-3 (with jack plate, tabs and tilt/trim tweaked, I cruise at 35 mph with a top end of 48 mph!) - 115 Evinrude Ocean Pro.
The one I found had only 2 owners and both live 200 miles inland. They only used it on vacations. It had only 153 hours on it and was kept inside all it's life. The hull still has "shine"! Yes, this is a great starter boat for salt and fresh water.
1998 Hydra Sports Key Largo 16 Color Large.1.jpg.
(I hope the 2 pics I attached display for you. The second one is the OEM ad. Enlarge it to see all the information).
rkmnoles
jbwilli, you describe the vessel exactly and the pics confirm. Not the same FL numbers and this boat was purchased in Gainesville. I did purchase the boat and I am extremly happy with it. It was repowered with a 130 hp Johnson and the trim tab pump had been removed which I have replaced. I have run it in 2-3 footers and it rides as smooth as you can it those conditions. My friend has a Carolina Skiff and I ran off and left him as he was getting pummeled. He can go slightly a bit further in shallow water but I can cast to him so not a big difference. I hardly ever have more than 2 in boat as that is my preference. All the pumps and lighting work. Decals were a little discolored and some greasy fingerprints but were easily removed with the Majic Eraser. I consider it a $4000 dollar prize! Thanks again.
Jtabares
JBWILLI - nice post. I too have this model in a 1998 25th Anniversary Edition (pic attached).IMAG0130.jpg
I have been going crazy trying to find the capacity plate information so that I can have one recreated for my boat. All I can see on mine is that Max people is 4. The rest of the plate is worn out. Can you please post on here ALL of the information said on that plate? If you can post a picture -EVEN BETTER!!! Your help will be GREATLY appreciated!
EDIT - ANYONE WITH THIS BOAT WHO HAS THE INFO I NEED CAN HELP!!!
Thank you!
H-S Boy
JBWILLI - nice post. I too have this model in a 1998 25th Anniversary Edition (pic attached).View attachment 198470
Thank you!
The main thing is maximum hp is 115. I still have the coast guard plate in my boat if you need capacity numbers.
jbwilli
Thank you!
I know it has been a few years since you asked this question, but here is the USCG MAXIMUM CAPACITIES for the 1998 HS 1650 Key Largo.
I still have mine. Do you still have yours?
I am looking for another HS 1650 for the family, for bay flats fishing. It is way cheaper to buy another 1650 than upgrade in size to the only other HS flats w/11 inch draft, the 19 Bay Bolt. The 1650 weighs in just under 1100 pounds and the 19 Bay Bolts push 3000 pounds. I see a few HS 1650's for sale, but they are way overpriced!
jbcurt00
Closed
Please dont drag up old inactive topics just to hijack it to talk about your boat and etc.
Thanks
Status
