1994 Bayliner Rendezvouse Ressurection
SteveinVA
Re: 1994 Bayliner Rendezvouse Ressurection
Just off the top of my head, I used about 20 gallons of resin, and a ton of glass. I bought a few rolls of the already cut @6inch and 12 inch stuff probably 25 ft of each one roll of 3 x 25 ft 1708 one roll of the 8oz mat 3x25 ft. Its hard to tally it all up in my head . I basically followed frisco jarrets methods. I spent more than I anticipated, but this girl had alot more surface area (bulkheads, stringers and such) than your typical flat or v bottom.
SteveinVA
Ok weather getting a little better now, so getting back at it. I had gotten the cap back on before winter hit...sorta. strangest thing the one area I would expect it to fit back together easily it would not. see pic. trying to force it on I cracked the glass, which probably isnt so bad since it wouldn't fit. Question is best way to fix this area. I am planning on getting it set where it should be, and laying a couple layers of 1708 on it. I have sprayed the hull beneath the area with mold release so hope the resin wont stick to that area. Sound like a plan? I'll post a pic of the ground/sanded down area later tonight.http://i1278.photobucket.com/albums/y504/audijunky_13/DSCN1741_zpsc73b6366.jpg
Woodonglass
Actually, getting the cap to fit back over the transom area is usually the most problematic. I'd prop up the cap with a 2x6 and then I'd grind down the top edge of the transom until the cap fit quite easily, then recoat the edge with resin and a layer or two of CSM. Let it cure and then re-fit the cap.
SteveinVA
Thanks for responding Wood. The actual area where it wasn't fitting was a corner behind the transom. And I cracked the cap in that area trying to force it so I kinda fo did what you said but to the cap and not the hull/transom. What I did do was grind down the busted glass, fitted the cap, coated the hull with mold release, tapped it off as well, and the put on a layer of mat, followed by 2 layers of 1708, and one final layer of mat. (kind of made the cap a little wider in the corner it was tight). sanded, filled with resin filler, sanded and gel coated. Doesnt look brand new but its solid. As of now I am waiting for a day off and decent weather to fit the outboard back on...Getting excited
Woodonglass
Hey, That works too!!!!:D Tis the Season for Excitement!!!! There's gunna be a LOT of Wet Hulls on the forum these days!!!! I'm happy for ya'!!!!
SteveinVA
SteveinVA
Finally the forums are working again. And The great unvailing happened over memorial day weekend. I got her launched, she rode fantastic. Had some issue with the old fuel lines at first, paddling this boat back to the marina with a broom was probably an interesting site, luckily the wind was at my back. After replacing those all was right with the world!!! The only thing I have now is the exhaust leak on the old force. I just take the cowl off while idling around the slip, she stalls out if I dont but once out of the slip I just put the cowl on and roll out. I love this thing...
She has been officially named Wife's Whim
Thank you so much to all the experts on here for helping along the way. With out you all and Frisco Jarretts Videos I never would have accomplished this.
SteveinVA
SteveinVA
Woodonglass
Uh Uhh, Nope NEVER Happened. I can't SEE a thing!!!!! Boat's still under construction. Liar Liar Pants ON Fire!!!!! He's Fibbin!!! Don't Trust Him!!! I'm From Missouri....Show Me!!!! Only believe 1/2 of what somebody tells ya!!!! Are you guys buyin this????
I guess what I'm tryin to say is.....POST UP SOME PICS MAN!!!!
GA_Boater
Do you have any links where I could buy parts for my 1994 Bayliner Rendezvous?
Welcome, huffer. Please start a new topic. Tagging on to an existing topic is considered hijacking.
