gator fan josh
Thread starter- Joined
- Oct 7, 2012
- 54
I bought a 2000 Four Winns Horizon last year that had a blown head gasket. After three head gaskets finding that the timing module and pick-up coil in the distributor where bad, the final thing I had left was to change the bellows and replace the gimbal bearing. I decided to document it the best I could so that maybe I could help someone who plans on doing this. There have been a lot of people helping me from the forum so I figured if I could help one person it would be my good deed.
Here is the thread describing my Head gasket problem.
http://forums.iboats.com/volvo-pent...-3-0-gs-keeps-blowing-head-gasket-607451.html
My setup:
2000 Volvo Penta 3.0GSPEFS
Volvo Penta SX-M 2.16 outdrive
The first step was to remove the drive, I followed these instructions. That are in the in the stickies. I also drained the gear oil.
Remove the three bolts on the cover of the shift linkage. Them remove the cotterpin and unscrew the cable end from the shift cable.
Next turn the outdrive to port and you can access the shift cable retainer, I removed the retainer completely but I think you could just loosen it.
I then figured out how I was going to support the outdrive while I pulled it off since I was by myself. I used a motorcycle jack that I clamped a 2x4 screwed to a 2x6 to create some sort of "forks." It actually worked alot better than I thought it would, and being able to adjust the height came in handy when reinstalling.
Now the Trim rams can be removed, I just followed the instructions in the pdf. it is pretty straight forward.
Now the drive can be pulled away from the boat. just remove the 6 nuts and it should slide away. I was able to pull the drive only about an inch away. The shaft was then stuck in the gimbal bearing and no matter how much I pulled I could not get it to come free. To get it off i hooked the trim rams up again and pushed down on the trim switch which extended the cylinders and freed the outdrive from the gimbal bearing. The out-drive then slid away from the boat easily.
I then got my first look at the gimbal bearing and I was surprised since I didn't think the leak was that bad.
I wanted to check my alignment before removing the old bearing and was greatly surprised how nice the alignment bar slid in and all the grease marks were even all the way around. This did give me a chance to really see how bad the bearing really was. Here is a video of me turning the alignment bar.
Now it was time for the real work, I started with the exhaust bellows; the hose clamp was easy to get to with a long screwdriver when I had the drive turned all the way to port. I then started to wrestle with the huge snap ring on the pivot housing side of the bellows, I finally gave up and just cut the bellows with a knife and removed most of it towards the bottom of the pivot housing. Then I could push the bellows with the snap ring out from behind the pivot housing. Then I removed the plastic nut from the water tube. The plastic nut is really big, the biggest socket I had was a 1-1/8" socket and it wasn't big enough. Even a 12" Cresent wrench wasn't big enough. I had a craftsman adjustable box end wrench and it luckily was barely big enough. You can see the water hose is this picture, removing the nut allowed me to pivot the housing further up giving me access to the u-joint bellows easily.
The u-joint bellows actually came out a lot easier than the exhaust bellows. The hose clamp was easy to reach and once it was loosened it was jut a matter of rolling the front lip out of the pivot housing and pulling the bellows out through the bottom of the pivot housing.
Continued below
My setup:
Continued below
