bellavista803
- Joined
- Aug 21, 2013
- 3
Im considering purchasing a dingy with a 40 hp 2004 yamaha 4 stroke triple carbs
Any problems with these engines especially carbs????
I have heard they have very small passages and clog easily
Also hard to sync
The carburetors in a Yam F40 are particularly problematic.
If you buy the motor, and if you have carburetor problems, remember the Yamaha F25. If F25 jets are installed in an F40 that won't run worth a darn, those F25 jets will make it seem like a new motor. Virtually all of the carburetor issues will be over. Just keep clean fresh fuel in the motor. Drain the carb bowls if it is going to sit idle for a while.
Any idea what it should cost to have the F25 jets installed??
I am having same issue. Just want to make sure I am reading this correctly. So you are saying to replace the jets of an F40 with the jets of an F25 or it has F25 jets and they need to be changed to another size jet?
