Woodonglass
- Joined
- Dec 29, 2009
- 25,933
Well then, That oughta be there fer a while!!! Are you gunna do any Zolatoning???
Looks good ! But your 3/16 off your original green marks ! Sorry your gunna have to tear it out and start over ...![]()
If the sheathing is still all good and not cracked then I'd disassemble and form a funnel from some plastic and duct tape around one end, hang from the ceiling in the garage and pour some brake fluid in the funnel and try and work the cable back a forth and see if you can get some lube down in it. If so you'll be good to go. Laying out on the driveway in the hot sun will make it all flexible again. Some simple green and a stiff bush should clean that wheel up nicely. You can get a New Rotary system with a New wheel for $155.00
Get new from where?? Im not married to using the original wheel....
