bigdirty
Thread starter- Joined
- Oct 4, 2013
- 652
Thanks guys
Hoping for some more decent weather this coming weekend, might be able to get another big chunk done..
To Axkiker;
I have a few ways I made templates/pieces to rebuild. It helps to have a 'road map' when you are putting it back together, from measurements taken while doing demo, try to make lots of drawings. As for odd shapes or curves , like the bottom of stringers, I put a straight edge/tape measure across the top edge, then measure down every foot or so, starting from one end. You will end up with a series of measurements you can transfer directly to the piece of wood (using the factory cut straight edge of the wood) and just 'connect the dots' so to speak.. For the V of a bulkhead say, use a straight edge running across the beam of the boat, sitting at the hight of the stringers in that area. Find center, measure down to the keel, then same thing, transfer measurements to the wood you are using and draw it out/connect the points. There maybe other ways of doing it (easier?) but that's just what I did.
To Axkiker;
